update 0.2: critical Bug Fix with contrary checkboxes regarding XML, do not use old version anymore. also ffmbc check routine implemented.
update 0.1b: as requested, now experimental build 0.1b online with audio stream copy. much faster! also removed messagebox popping up for no reason.
Hello,
I wrote a little Tool called WinRewrap. It will Batch Process MTS Files to MP4/MOV and adjust References to the MTS accordingly in your XML File. It uses ffmbc. I wrote it primarily for exchange between the new Sony Vegas Pro 12 and DaVinci Resolve. But it can be used for any Batch rewrapping task of MTS.
Of course, this is a very early version, so please let me know any problems that may occur.
I hope you can use it as well as I can.
regards
FatPig
https://rapidshare.com/files/3957295853/WinRewrap_02.zip
README:
Initial Release of WinRewrap 0.1
Requirements:
ffmbc.exe (Release was tested with version 0.7.1 rc7) put it in the same folder as the WinRewrap exe.
Windows 7 / Vista Users may experience errors related to writing permissions. to fix those, copy WinRewrap and ffmbc.exe to your Project Folder. (Tip: WinRewrap starts with its containing Folder under the Browse Dialog, If its your project Folder you can just click OK.)
Features:
support for rewrapping .MTS Files to .MP4 and .MOV using ffmbc.exe
this is essentially a frontend for ffmbc, designed for batch processing project folders containing multiple MTS Files and optionally an XML.
This enables project export from The New Sony Vegas Pro 12 to DaVinci Resolve, and can also be used for normal batch processing of entire Folders from GH2, etc.
It can automatically replace the MTS references to your new chosen Container (MP4/MOV) inside the XML.
Ideally, without subfolders.
Bug reports please here
regards
FatPig
