Windows 7 KVM work-around
WpgCameraMan
My editing desk is pretty much where I spend most of my day, but it's uncluttered with the usual items. I have another very small office where I do the books and such.
Up until 2 months ago, I was using Windows 7 on my surfing computer, and XP on my CS4 NLE. A Dell 24", keyboard and mouse were hooked up to a KVM between systems. I've now switched to CS5 and Windows 7, added two more monitors (FullHD program monitor and an extended desktop for NLE).
Using my older PS/2+VGA TrendNet KVM, when I switched back to the NLE, it would disconnect from my added screens, screw up my workspace. It's a thing Win7 does, always looking for new hardware but also reacting when you disconnect something. At some point I'll have to get a compatible KVM..
My work-around is using Remote Desktop. My surfing box is on most of the day, and I need to refer to it often for email, but resetting my screens all the time is a pain in the butt. So when I turn the NLE on, I switch the KVM to that system, when it's booted, access the surfing PC with Remote Desktop, and voila, I can check my email, surf, and still have full use of the NLE and it's resources. Playing higher quality web videos is a bit jerky, I'm probably bogging the surfing PC down, trying to encode on the fly like that (Intel Dual Atom 1.6ghz vs. Phenom II Quad 3ghz+GTX460).
Anyways, Remote Desktop ... it's a viable fix to a problem with Windows 7 (but marketed as a feature).
Yes, that is another option, but it involves switching monitor inputs back and forth, and my expensive Dell 24" has 8 inputs and the 'Source' button cycles through all of them... the picon has already rubbed off, and the button is starting to get 'soft'.
I may try a combo of the two, as the VGA from the NLE is a bit 'shimmery' at 1920x1200. As long as the same mouse and keyboard can be used for both, then I'm happy.
Use on board monitor switching with a high-speed y-mouse adapter from PI Engineering for peripherals with a dedicated, high speed processor built-in.
