Joshua Cadmium
Hello!
I have the legendary Willytec Follow Focus up for sale. (It was designed by Jim Elias, who also had design input on the Arri LFF-1 and FF4, the Oconnor CFF-1, and the Bright Tangerine Revolvr line.)
It comes with enough bits to make its single rod handheld version (which is very similar to the LFF-1) and its 15mm studio version. It does not have any extensions and only has the handheld knob, so it is only for use on one side at a time, without the two speed knob and without the use of marking disks. I also only have one gear, which is the larger one designed for the Cooke 20-100 (but it will, of course, work with any lens.)
Since the port for the knob is a standard 12mm square coupling, you can take off the knob and plug whatever you want directly into it.
The follow focus is fully reversible for use with Nikon lenses.
There is a tiny bit of blacklash, but it is in good used shape.
I'm asking $900. Feel free to send an offer as well.
Thanks!
Thanks!
