Will you be able o do the frame rate hack on the HMC?
joshuadixonmedia
I need to overcrank and undercrank and I primarily shoot in 24. So I need at least 48 available.....I am not seeing this anywhere at all that it is available on the camera. So I know of people being able to do a hack with a memory card that allows you to change standard settings....I'm not sure if the camera takes a memory card to store settings, but if it does can we do the hack on this camera also? I believe Barry Green is noted for it originally...
Thanks.
-Josh
The HMC 150 does not do variable frame rates so there is no way to hack the variable frame rates.
What you can do is shoot 60i and convert that to supersmooth slow mo in post just like people do with other non variable frame rate cameras.
