I'm trying to record and monitor audio into the camera and onto the LS-10 simultaneously using the Studio 1 Productions XLR-BP, which is an XLR adapter.
Here's the issue:
I can record fine into the LS-10 on its own, monitoring the audio on my headphones with the LS-10's headphone jack.
I can record fine into the GH2 directly, without monitoring the audio on headphones (no headphone jack).
I want to be able to monitor audio as it's being recorded into the camera, but I'm not aware of any way to do this.
Here's my question:
If I connect the XLR-BP to the LS-10, can I use the LS-10's line out and connect that to the GH2's mic input using a 3.5 to 2.5 adapter? If so, can I then use the LS-10's headphone jack to keep track of this audio feed?
I currently only have a stereo 3.5 cable so I would presumably need a 2.5 cable, correct? Assuming I had this cable would it work? Or is this a bit too complicated of a wiring mess to be worth the trouble? What are some ways some of you have been able to monitor GH2 audio with headphones without using Dual Eyes and syncing later?
Here's the issue:
Here's my question:
