will this lens work with AF100??
To use this almost 40 year old 20-120 with your AF100 you would need a BNCR to M4/3 adapter, and a rail mount lens support because of it's weight.
The lens was designed to cover standard 35mm film, and will cover the AF100's sensor just fine.
Good Luck!
Dave
Would work, yes. Not the sharpest glass, but ... well, let's put it this way -- you'll probably be shocked at the size and weight of it. Probably a foot long and 10 pounds heavy. You'll need a BNCR adapter (available on ebay) and a rails system with a lens support.
I hope you won that lens.
Has anyone tried the Kowa Zoom C-mount F2 17-102mm lens with the AF100? Will this cover the m43 sensor? I am not sure if this is the appropriate place to post this question and I don't mean to hijack the thread. I will move this question else where if I need to. Thanks!
I haven't found any c-mount zooms that cover the AF100's sensor. Remember that c-mount was originally for 16mm film, and the AF100's sensor is over 3x bigger than 16mm film. You can find some c-mount primes that will cover, but I haven't found any zooms yet (others may have, I just don't know about 'em).
