wide angle 0.7x
cityboynewyork
I just bought this wide angle 0.7x century, guys gudie me with tips and trick. BTW can I always keep it and shoot my entire proejct? I use to do that with my 16:9 adopter...
there aren't really any tips.
if you want a wider look, you just use the wide angle lens so you get a wider shot. that's it...
I use my wide angle lens when ever I need a wider shot at a tight space. (mostly in rooms)
sometimes the stock lens isn't just wide enough
btw, the 0.7x lens is not the same as the 16:9 adapter.
you wouldn't leave a wideangle converter screwed on all the time, because you don't want to produce a film that only has wide shots...it's that simple.
