why quicktime limited to export
djgvinny
hi , im using premiere cs4 , HD footage , when im exporting in quicktime format thats what i get in preset
custom
ntsc dv widescreen
ntsc dv widescreen 24p
ntsc dv 24p
pal dv widescreen
pal dv
and when i use other format i get all presets
why i dont get the hd's format quicktime and what can i do to fix it ?
thank you
when i click on the prest , thats all i get
custom
ntsc dv widescreen
ntsc dv 24p
pal dv widescreen
pal dv
is it the way it should be ? or should i download presets ?
i looked in preferences , theres no such thing as output module setting
here what i get
general
apearence
audio hardware
audio out
audio maping
auto save
cadpture
device control
label colors
label default
media ....
even if i click in media theres nothing that would lead you to quicktime
custom
ntsc dv widescreen
ntsc dv 24p
pal dv widescreen
pal dv
thank you
Choose "custom" from the presets list, that will allow you more options.
- Mikko
- Mikko
i try that allready , but i still dont have HD format preset for output , either i get none compression or i get regular dv qualitty
in the other hand if i choose mpeg or others i get all the presets for the HD .........
There won't be any labelled HD presets from the AME encoding window queue.
When you click on NTSC DV or any other preset, it will open up a new dialog box labelled "export settings"
In the video tab, twirl down the video codec menu, there will be a drop down menu and you can select from all your QT profiles.
If you select an HD format, you will get access to HD resolutions
