Barry_Green
Moderator
According to the manual (PDF pg. 35, you can also record VFR in 24P or 30P at 720. But on the previous page, the manual seems to contradict itself, and says something about "without the use of a frame rate converter", it must be PN mode.
Can somebody clarify this?
The 720pN mode includes a hardware frame rate converter. The 720p mode doesn't. If you shoot in variable frame rates in 720pN mode, you see immediately the slow-mo or fast-mo effect. If you shoot vfr in the 720p mode, you won't see the effect until the footage has been processed through a frame rate converter (either hardware or, far more commonly, software).
