Why can't I export a .mov quicktime movie from FCP 7.3 that looks EXACTLY like the image I get when playing the footage in the timeline?
These are my 2 biggest quality issues that I can't find a way to surmount:
1. Interlacing. Yes, I shot interlaced - bad idea, never will do it again. But in FCP, viewed at full screen, the footage is beautiful - no interlacing artifact at all. Once exported, it looks horrible. Please no comments about "just choose 'deinterlace' when exporting." This seems to horribly degrade the quality (see below) and it doesn't deinterlace it anyway at the same resolution as I'm viewing it in FCP - you have to scale the quality down from 1080i to 720p before the interlace artifact in the exported file is gone. And even then, the quality is much worse than 720p should be (see below).
2. Saturation/bit depth/color quality: Once exported - no matter what quality I choose and no matter whether I check 'deinterlace' or not - the color goes down the drain once exported. It looks pathetic. Oversaturating the image before exporting in hopes of a correct saturation by the time it's exported does not work. The image is simply very, very washed out once exported.
Bottom line: If the footage looks beautiful IN final cut, viewed at full screen, we KNOW it can look beautiful OUT of final cut, viewed on the same screen. How is this accomplished?
A few technical details:
Footage specs:
Shot in 59.94i, 1080
AVCHD
.MTS
Imported RAW into FCP using Log and Transfer.
Once ingested into FCP (using default ingest settings):
29.97i
1920x1080
Upper (odd) field dominance
Square pixel aspect ratio
Apple prores 422
Export specs:
Compressor: H.264
Frame rate: Current
Keyframes: Automatic
Data Rate: Automatic
Frame recording: Unchecked
Quality: Best (multipass)
Encoding: Best quality
Export size settings:
I have tried all of the following settings, each with 'deinterlace' checked AND unchecked, respectively. And each with bad results:
1920x1080
1600x900
1280x720
and other sizes of 16:9
Any ideas on this is HUGELY appreciated.
Footage specs:
AVCHD
.MTS
29.97i
1920x1080
Apple prores 422
Export specs:
Compressor: H.264
Frame rate: Current
1920x1080
1600x900
1280x720
