Why does frame rate change back to 24frames when camera is turned off?
Skajrishma
Hi, I have a question about frame rates. I was shooting onto to Firestore at 720P/24P and 720P/24PN on P2 and set the camera frame rate to 60frames. When I turned off the camera and turned it back on, my frame rate changed back to 24frames. Why does it revert back to 24frames? Is there a way to keep it at that without going in and changing it every time I turn the camera off?
Thanks.
Skajrishma
You need to save your scene file. If you don't, it will revert to the last saved state when you turn it off and on again.
You don't need to worry about losing anything -- you can always revert to the initial state of any scene file.
