I am having a recurring problem that seems to have no solution.
I am using Sandisk 32GB SD Cards in a RAW SxSxSDXC Adapter for recording the footage acquired from my Sony EX1. I have shot many hours with them and all worked fine. But, now something is happening that has not happened before.
After downloading the footage into my PC and I put the card back into the camera, it says, "Media Error - Media Needs To Be Restored". But, it does not matter if I restore it or reformat the card, the camera will stop recording, and it will pop that error message back up after just a few minutes of shooting.
It seems the ONLY way I can get it all to work again, is to go into Properties, Tools, and Error Checking which checks the drive for errors. It then scans the card for system errors and recovers bad sectors. After ALL THAT is done, it will then work in the camera again. But, after shooting and downloading the footage, I have to do it all over again.
Why won't it work in the camera by reformatting, etc.?
BTW - I've tried other SD Cards, and other Adapters, and it makes no difference.
Any help or advise is appreciated.
Thanks.
UPDATE:
I was just going over the specs of the EX1 and maybe I've solved the problem. It has a write speed of 35MB/s, and the SD Cards I've been using have a speed of 30MB/s. Therefore, maybe the camera is putting out data just a little faster than the cards can absorb, especially when the camera is left on for long periods, which is what I've been doing lately.
So, with that in mind, I have found these new cards that just may do the trick, with a speed of 95MB/s. What do you think?
See here:
http://www.amazon.com/SanDisk-Extre...T3QG/ref=sr_1_1?ie=UTF8&qid=1329603920&sr=8-1
This is, of course, assuming the problem is with the cards and not the camera.
Thanks.
UPDATE:
See here:
