I have noticed that different cameras produce different kinds of flickering on the same florescent or led light even when recorded at the same frame rates to each other. Tried NTSC 24, 30, 60, Pal 24, 25, 50.
I thought the flickering could be stopped if you set the frame rates at the power hz rates for your country which is 50 for Australia.
Gopro seem to have produced the best minimal flickering when set at 50fps.
What causes these differences and how come it has not cancelled out the flickering when I set the same fps as the power hz?
Can you remove the flickering in post?
