Why are these LINES haunting me?
IncMedia
Does anyone know what I am doing to get these lines in my shots.  They are haunting me. ???
       HELP :-[ :-[ :-[
Re: Why are these LINES haunting me?
Those are because of interlacing. Do you mean when you take screenshots in your NLE because if so (well if it is Vegas anyway) if you go to the movie properties and make the footage deinterlaced you can take save screenshots without those lines.
on a progressive display like a computer screen, interlacing is going to be very very visible.
de-interlacing or some sort of frame interpolation are the only way to get rid of those lines.
Shooting in a progressive mode like 30p or 24p will eliminate those lines.
If you take your frame into photoshop and use the filter/video/deinterlace it will correct this problem for stills. These are not a probem when watching on an NTSC monitor. hope this helps.
-T
Are you sure this is not a reversed fields problem ? Because it looks like that to me.
(Upper field first or last)
Do you see this on running footage - not just screen grabs ?
Yes
I can see them on running footage. I can also see them on the video when I render.
Im using premiere pro 1.5
In that case - You have got your interlaced fields in reverse order and the video is playing the wrong field first. (Its a time thing and what you are seeing is a fraction of a second later being played a fraction of a second ahead of itself- does that make sense ? :-/)
I fully understand you. ;)
Now all I need to do is get rid of it. ???
You are either capturing or out putting with the fields reversed.
Do a test.
1st - Check what your project setting is for field order in your NLE.
Then: Capture short length of footage using both options. a: Upper field first b: lower field first.
See which one is right and stick with it.
Good luck
Assumeably if you shoot "p" mode this problem does not show.
i hadthe same problem, it was motion blur, go into speed and turn off motion blur.
hopefully that helps
Deinterlace Fields.  After I selected that option it went right away.   ;D
