AmbiSonde
Carbonite Member
FX30 XAVC-HS has 200 mbps at most, XAVC-SI has 600 mbps. How come XAVC-SI is noiser than XAVC-HS? If using XAVC-HS 200, grading may be an issue, in camera adjustment may be the way to go.
You are ignoring the fact XAVC-HS is HEVC which is 2x as efficient as h264 so 200 Mbps performs like 400 Mbps, HS is also long GOP whereas XAVC-I is intra frame so XAVC-I is actually at a bitrate disadvantage per frame.
I have thoroughly tested XAVC-HS against XAVC-I and HS wins across the board, as I said, it is less compressed there are almost zero compression artefacts and therefore more robust in post production. In comparison XAVC-I destroys fine detail and has a significant amount of mosquito noise. The only advantage to shooting XAVC-I is if you have an older computer that does not have GPU acceleration of XAVC-HS. If you have a modern PC with quicksync XAVC-HS edits like intra frame anyway.
What I found surprising was that XAVC-S was also better than XAVC-I on the FX30. I was not expecting that. I only tested that at 25p though.
The FX3 and FX30 have Sony's latest codecs, they're better quality and much more efficient than those in the FX9 and FX6 so only the FX9 recording externally to RAW will beat the FX30 for detail. I've seen plenty of owners of both the FX3 and FX30 say the FX30 clearly has a more detailed image. I've seen a number of FX3 owners who bought the FX30 as a cheap B camera who've ended up using it as the A cam and the FX3 as the B cam. The image coming out of the FX30 is exceptional.
If you're considering a new camera then you'd be crazy not to take a good look at the FX30. The advantages the FX3 has is low light performance, it can do full sensor RAW and if it's important it is a full frame. Sony has limited the FX30's RAW output to 4.7K crop which will be like S16. I don't begrudge them that, if they'd given full 6k S35 16 bit RAW out they'd kill the FX9 and no one would buy their expensive detachable sensor block for the Venice.
I would wait to buy a Mark II FX9 or FX6 as Sony will surely bring XAVC-HS (they'll probably call it XAVC-H) to new camera models when they refresh the line-up which will also bring all the AI auto-focus enhancements. It almost feels like the FX30 is the first camera in the next series rather than the last camera in the current series and it signals what to expect next from Sony.
I don't think Sony had much choice but to release the FX30 with these specs, the competition for small and hybrid cameras is intense, the Fuji cameras are also excellent in this price range which are also worth looking at. If Sony had released a crippled S35 camera no one would've bought it and they would've lost huge numbers of sales in a very important segment. As it happens Sony can't keep up with demand for the FX30, it's flying off the shelves.
I forgot to say it's not all good news about the FX30. I forgot to say the audio recording is sub-par, the audio pre-amps are absolute shite so having a good audio recorder is vital if you have any concern whatsoever for audio. I have a Sony A10 that I mount on the rig and pass through audio into the FX30 via the 3.5mm jack and I sync and replace audio in post. Sony in camera audio has always been, at best, barely satisfactory so I doubt any of the FX cameras are anything to write home about.
