Why am I getting "NO Valid Picture to Play" after trying to install Firmware?
JoeJITSU
Ok, I uploaded for the first time yesterday the firmware GH1__132 with "version change" ticked, "24P Native" ticked and "C"settings. I incremented version change to "2" and saved as "GH1__140" . I copied and pasted to the outside of the 3 folders on the SDHC card Patriot 32gb class 10 card. Then inserted the card into the GH1 powered it and pressed the "playback" (green arrow) button. said "upload 1.3" after a minute it was uploaded.
Today, I went to Ptools uploaded the "GH1__132" then ticked "version compare" ,"24p Native" and the "C" settings. I then saved as "GH1__141". I then copied and pasted to the outside of the 3 folders and took the SD card put into GH1. Powered it on and pressed "playback" ,now it says "no valid picture to play". I even redid the firmware and named it "GH1__140" still same thing. I know its something simple. Please help. Thanks
Thats what I thought. But on other threads they are saying that "version change" does not have to be ticked. THanks for the quick response.
you did not mention you ticked version compare patch in your first update but only version change. you need to tick both in your first patch if you wan to be able to update any version after that. do another patch with both ticked and version increment higher than your first value of 2 and update it. you then dont have to tick version change after only compare patch
Do you have any footage or photos on your SD card? If not, it will say, "No Valid Picture To Play". Shoot some footage and this message will go away.
Thanks, this solved it. You MUST tick version change AND version compare the first time.
Another reason you will get this is if the cable you use to plug the camera into the computer is still plugged into the camera. Simply unplugging the other end from the computer is not enough.
Shawn
This is my first time playing with 3.40d. Previously, I've been on 3.36
I downloaded the ptool today.
I loaded the original 1.32 firmware along with lpowell's reliable in-camera playback patch. This has both 'version increment' and 'prevent version compare' checkboxes ticked
I saved as GH1__1.33.bin. I have also tried saving as GH1__1.40.bin (under 3.36, the highest number patch I saved was 1.39)
When I try to update the firmware, I too get the error message 'no valid picture to play'
I'm sure I'm missing something simple.
Anyone have any ideas?
Hi All. I recently tried the hack and had issues. I would like to restore firmware to the latest factory settings. I have closely followed the procedures outlined in this forum but have had not success. Have ticked version change AND version compare, and saved as new bin # but still get the "No Valid Pictures" . Any help would be much appreciated. Thanks!
Success! I realized that for my first botched hack I did NOT have the Version Compare boxed ticked and I had mistyped a large number in the version increment box when I saved the firmware. I just needed to make it a larger increment than my original value and then the camera updated to the new firmware! This time around I DID tick both version change AND version compare so I should be OK if I try this again. Thank you for your help!
The first time you hack you need to click both version change and version compare with an increment higher then your current firmware.
Everytime after that you hack you just need to click version compare and should not click version change. You should see a firmware version of 0.0.0. This allows you to go back to factory 1.32 firmware down the road and it's as if your camera was never hacked.
Shawn
I would highly recommend you do NOT try to hack your cam having it plugged into your computer. I didn't even think that was possible... you're opening yourself up to a world of bad possibility doing it that way.
I just opened the original firmware GH__132 with ptool. I noticed that in the AVCHD compression settings there is NO selection box for "Limiting Bitrate". This is a value to set in the DVXuser video tutorial I watched. Anyone know why that selection seems to be missing from my hacked original firmware? I downloaded the original firmware from the Panasonic site. Thanks.
It is missing because it is integrated with other patches in all new PTool versions.
It is not related to firmware :-)
Thanks Vitaliy!
At this point I only have class 6 SD cards. They work just fine with original firmware. I have a class 10 card on order. Will the class 6 cards work at all after the recommended hack? Is there any risk in trying them? thanks.
