Barry_Green
Moderator
Check it out: while the nanoFlash records MPEG-2 off HDMI and costs almost $3,000, BlackMagic is releasing an h.264 recorder, that records from both HDMI and HD-SDI, for almost 1/10th the price! Not only that, but it also captures component analog video, so if you had an HDV or HVX camera that don't have digital HDMI or HD-SDI outputs, you can still use an external recorder!
http://blackmagic-design.com/products/h264prorecorder/
Man, reading the specs, this thing is crazy... 12-bit input, records at 4:2:2, supports 1080i, 720p, 1080p, in 25/30/50/60 modes, also stores 24PsF, and records at 12-bit(!) Even supports 3G HDSDI!
This thing looks seriously too good to be true. Only thing I can't find is any definition of the bandwidth/file size of the recorded files. All it says is that it supports many scalable h.264 formats, so it can record directly to a small file for uploading to the web, or in an iPod or iPhone-compatible file format, or "full resolution HDTV".
Here's the brochure:
http://blackmagic-design.com/downloads/brochures/H264Encoding.pdf
It says it captures video files for "the iPod, the iPad, the web and more". So maybe it's dumbed down? But if it captures 12-bit 4:2:2 at "full resolution HDTV", why would it be dumbed down?
Okay, last thing -- I can't see where it has any recording media in it. So perhaps it's not a standalone recorder, but needs to be hooked up to a computer via USB? If that's the case, it's not nearly as interesting, but still pretty darn cool for $349.
Available in July.
Available in July.
