XLR inputs are mono![]()
Yes, always. Balanced mono inputs.
And preamps of both units are badly suited for good sound due to very weak preamps.
Even hot mike do not save them most of the time.
So, you need good preamp anyway.
DR-100 is better IMO for several reasons but the biggest one for me is the level knobs on the side.
I have the Marantz 661 - great in every way. No issue whatsovever,
and the Tascam DR100 - the premap is a bit noisy, and the overall gain a bit low. Otherwise the sound is very good. If you have hot (high output) mics the DR100 should work just fine - both issues become non issue.
Had the Zoom H4N, and IMO it is not a good recorder. Main issues are inaccurate clock (causing audio sync drifts), and very high harmonic distortion (not suitable for music). Also noisy preamp and overall low gain. Sold mine soon after I bought it.
SD MixPre feeding a line-level signal to a Sony PCM-M10 would be a versatile solution. The PCM-M10 gets excellent reviews. This is the setup I'll be using when my GH2 arrives.
