I am just curious if anyone else has had issues with the results of white/black balancing at the same time. I have found that the white balance doesn't always work if you also black balance in the same instance. If you white balance separately it seems to work fine.
From Barry's e-book:
"...all you have to do is hold down the AWB button a bit longer. If you release the AWB button right away, the camera
will do only a white balance; if you hold the button down longer it will do a white balance followed immediately by a black balance..."
