HansK said:First:
RTM
Second:
Check the setting of the white balance switch. There are three states; A, B, PRST. If you press the AWB when the switch is set to:
A or B - The camera automatically calcs the white balance and then assigns that setting to the A or B memory value.
PRST - The camera displays the current temperature setting, either 3200K or 5600K. Each press toggles between these two presets.
Be sure to have the camera viewing an evenly lit white surface when you set the A or B values. Also, have your shutter speed set correctly.
