Which version of AVID will work with 25P PAL ?
goerik
Hi there all,
I have the following problem. When starting a new project, I have only the following choices for the format :
- 23.976p NTSC
- 30i NTSC
- 25i PAL
But when selecting 25i PAL, i have also the next settings which i can select :
Film Type :
- 16mm
- 35mm, 4 perf.
- 35mm, 3 perf.
Does above like Film Type means this is the setting normally know as 25P PAL ?
Or does this version of Avid does not have the possible of 25P PAL but only for 24P NTSC ?
Do I need to change to a another version of AVID ?
Hope to hear from you.
regards, Erik
Goerik,
Do you use Avid Xpress DV or Avid Xpress Pro? And what version are you running?
You need Avid Xpress Pro v4.5 or above for 25P projects.
