Much thanks for a quick reply… I leave for the Andes tomorrow. I will be in the field without support for nine days.
I just received my H4n. I will use the H4n to record sound in conjunction with shooting video on my EOS 550D (for video almost identical to the 7D).
My main questions are: what recording mode should I use?
2) I am using a 16G card so storage is not that much of an issue. I am guessing that I want to use one of the WAV modes
3) If I adjust the levels manually what level am I shooting for?
Just as a double check:
Thanks, DCAD
- 16bit/44.1 KHz or
- 16bit/48.0 KHz or
- 24bit/96.0 KHz
- -24
- -12
- -6
- I have the recorder in “Stereo STAMINA” mode
- I am using 2100mAh NiMH cells (3 pairs)
- I have a Rycote Mini Windjammer (which just fits over the foam windscreen)
- I am using the built in mic’s. I understand they are at least decent.
- For the most part I will probably use the 120 degree mode to get stereo ambient sound from the Andes
- I will switch to 90 degree mode if I wanT to focus on someone talking. AND try and get the mic fairly close to them
Thanks, DCAD
