Which OS For Avid?
mdslammer
Hello,
I'm currently using Adobe Premiere Pro CS4 and Vegas Pro 9 for my NLE. I bought
Avid Media Composer a while back but I won't install on my current OS (XP Pro x64).
I have removeable hard drives for my rig. One for audio and the other for video.
I'm going to have the new drive configured next week but I'm still debating which
OS to go with. Windows Vista x64 or Windows 7 x64.
Any advice as to which OS to choose, pros/cons or any other advice would be
greatly appreciated.
Thanks in advance.
Mark Dalzell / Las Vegas, NV
PC Specs:
VisionDAW 4U 8-Core Xeon Workstation
2 Intel QUAD-Core Xeon 5365-3.0GHz, 8MB, 1333MHz Processors
16GB 667MHz Fully Buffered Server Memory Modules (2x2GB)
Microsoft® Windows® XP Professional x64 Edition
WDC 250GB, Ultra ATA100, 7200 rpm, 8MG Buffer Main OS HD
MOTU 24 I/O (main) / MOTU 2408mk3 (slave)
2 WDC 750GB, SATA II, 7200 rpm, 16MG Buffer HD (Samples)
Plexor PX-800A 18X Dbl. Layer DVD+/-RW Optical Drive
Front Panel USB Acess
Integrated FireWire (1394a) interface
Thermaltake Toughpower 850W Power Supply
Dual ESATA Bracket
2 WWDC 750GB, SATA II, 7200 RPM, 16MB Buffer HD (Raid 0)
3xUAD1 Universal Audio Cards
NVIDIA QUADRO FX 1800 / Memory 768 MB GDDR3
CUDA Parallel Processor Cores / 64
Maximum Display Resolution Digital @60Hz = 2560x1600
Memory Interface 192Bit
Memory Bandwidth (GB/sec) / 38.4 GB/sec
PCI-Express, DUAL-Link DVI 1
Digital Outputs 3 (2 out of 3 active at a time)
Dual 25.5" Samsung 2693HM LCD HD Monitors
Windows 7 isn't even released yet, so it's definitely not qualified, and it will probably be a while before it is. If you need your system to work, go with an approved OS, which is:
Windows Vista Business or Ultimate 64-bit for Media Composer v3 and above.
Michael
There are some guys that are running windows 7 on the avid forums, guess it's a beta version? A few problems were reported but now that looks like it was just a driver for a certain video card that is easy to fix.
If your going to start a big project use vista 64 business or ultimate and hold off for 6 months on the windows 7. FYI if you buy vista 64 business or ultimate now you get a free upgrade to windows 7 that you can intall anytime you want in the future.
They are reporting windows 7 runs much faster than vista 64, has better usage of ram.
MDSlammer,
Just a heads up the adrenaline break out boxes (not sure on the mojo's) don't work with windows 7 in case you ever want to pick a used one up off ebay in the future. You have such a hot rod computer you'll probably never want to.
