mccannondsl@eircom.net
Is the line level on the 302 less sensitive than typical camera line level inputs?
I just recently acquired my 302 so I'm working my way through the settings and configurations. I set up channel 4/5 today and plugged in my AT 1800 receiver to find that the input level was a little lower than I might have expected even with the output level on the 1800 maxed. I then tried my Sennheiser G2. This was a bit more respectable - with the RTN Gain turned fully up I was getting a good level.
I then tried both receivers on the XLR inputs - again the Sennheiser was stronger - With the Gain and Fader fully up I was getting a good level. I then tried the receivers with the INPUTS set to MIC LEVEL - now, I could set the Gain and Fader to unity and I was getting a signal of approximately the same strength. Again the AT 1800 was a few pips lower but the signal on MIC level was acceptable where the Line level was a bit low.
As it so happens I haven't been recording camera sound for a few years so I'm rusty but I'm sure I've never used MIC level with with either receiver before and I've never found the signal to be too low - that's going straight into the camera.
So, it seems Mic level is the way to go.
It appears that channels 4/5 are not a option for the AT 1800 and the G2 is just about usable on 4/5.
This isn't what I expected - could I be doing something wrong here?
