Which 35mm adapters are compatible with the HPX170?
JPUSC
I'm trying to look for an affordable 35mm adapter for the HPX170, but I keep coming across ones that were designed for consumer cameras. Any suggestions?
Does the Jag35 work with the HPX170?
Almost all 35mm adapters work with the HPX170. Letus, RedRock Micro, SGPro, Mini 35, ect.
You just need the 72mm connector to connect the camera to the adapter.
Look at the Letus Ultimate or Letus Elite.
Also the Jag35 will work, but you'll need to get a model that has a 72mm thread attachment.
I'm a big fan of the Brevis, it works very well on my HPX170. Just thought I'd mention it here since it wasn't in Andrew's post!
Thanks a lot for the replies! I think I might go with the Jag35 for now. Any feedback on the Jag?
