TheMacB Veteran Nov 6, 2007 #1 home depot only has pvc with a bell shape at one end. so it isn't flat. is there anywhere else to get it?
Kevin Lee Veteran Nov 6, 2007 #2 Ace Hardware, Lowes, almost any hardware store. If you dont see it, ask at the front for schedule 40 PVC, it comes in 10' lenghts.
T tcindie Well-known member Nov 6, 2007 #3 You should be able to get shorter lengths too.. I regularly buy 5' lengths.
Neal Buconjic Well-known member Nov 6, 2007 #4 The "bell shaped" pvc you are referring to is for electrical conduit. Check in the plumbing section for the appropriate pvc.
morten Well-known member Nov 6, 2007 #6 plumbing section. white ugly 10 foot tubes with blue print on the side. dirt cheap mor10
J jamesstone Member Nov 7, 2007 #7 The "bell" is the built in coupler on 20 foot sticks. The 10'sticks do come from the supplier without the coupling on it. If you want long one piece sticks, it would be easier just to hack it off. You only loose about 2" James 9 yr OSH plumbing associate.
