I hope someone here has had this problem and figured it out. I can't figure this out and am done trying to rack my brain on it... no matter what I shoot DV, DVCPRO50, DVCPROHD (720 or 1080) when I import the MXF it says that it is 16:9 clip in P2 Viewer and they look 16:9. I then convert the files with CIneform and somehow they turn into 4:3 clips. I thought at first it was a Cineform setting, however I was just playing around with scene files and switched the dial and the next 2 clips I imported were 16:9 and converted to 16:9 just as I want.
What setting could I possibly be overlooking in the camera? Sorry for the lengthy post below...
Thanks in advance!!!
Record Format is 480i/60i- DVCPRO50 (but I get the same results if I change it to DV or DVCPROHD, too)
0000A000: 9 ; REC FORMAT**: 480i/60i
0000A001: 0 ; REC FORMAT**: 480i/60i
0000A002: 0 ; 480i REC MODE : DVCPRO50
0000A003: 0 ; ONE SHOT TIME : 1F
0000A004: 0 ; INTERVAL TIME : 2F
0000A005: 1 ; PREREC MODE : OFF
0000A006: 0 ; REC SPEED : SP
0000A007: 1 ; AUDIO REC : **(16**)
0000A008: 0 ; MIC ALC : ON
0000A009: 0 ; MIC GAIN1 : -50*
0000A00A: 0 ; MIC GAIN2 : -50*
0000A00B: 0 ;
0000A00C: 0 ; 25M REC CH SEL: 2CH
0000A00D: 0 ; 1394 TC REGEN : ON
0000A00E: 0 ; TC MODE : DF
0000A00F: 1 ; TCG : REC RUN
0000A010: 0 ; FIRST REC TC: REGEN
0000A011: 0 ; 1394 UB REGEN : ON
0000A012: 4 ; UB MODE : FRM.RATE
0000A013: 0 ; **(12**)AUDIO : ST1
0000A014: 0 ; AUDIO OUT** : CH1*CH2
0000A015: 0 ; AUDIO OUT** : CH1*CH2
***I can't find anywhere in the camera where this is set at or has an option to change it***
0000A016: 4 ; FORMAT SEL: 720P/60P
0000A017: 0 ; PULLDOWN SEL: 24P
*** to here***
0000A018: 0 ; HP MODE : LIVE
0000A019: 0 ; A.DUB INPUT : MIC
0000A01A: 1 ; 1394 OUT: OFF
0000A01B: 0 ; MARKER: ON
0000A01C: 0 ; DATE/TIME : OFF
0000A01D: 0 ; LEVEL METER : ON
0000A01E: 0 ; CARD/TAPE*BATT: ON
0000A01F: 1 ; OTHER DISPLAY : PARTIAL
0000A020: 0 ; CAMERA DATA : ON
0000A021: 1 ; MENU BACK : OFF
0000A022: 0 ; REMOTE: VCR1
0000A023: 0 ; 1394 CONTROL: OFF
0000A024: 0 ; 1394 CMD SEL: REC_P
0000A025: 0 ; END SEARCH: BLANK
0000A026: 0 ; PC MODE : USB DEVICE
0000A027: 0 ; REC LAMP: OFF
0000A028: 0 ; ACCESS LED: ON
0000A029: 1 ; BEEP SOUND: OFF
0000A02A: 0 ; TIME ZONE : 0:00
0000A02B: 1 ; POWER SAVE: OFF
0000A02C: 0 ; LANGUAGE: ENGLISH
0000A02D: 1 ; 1394 IN PRESET: OFF
00000001: 0 ; REC FUNCTION: NORMAL
00006000: 2 ; ASPECT CONV : SQUEEZE
00006001: 1 ; SETUP** : 7.5%A
00006002: 0 ; SETUP** : 0%
00006003: 3 ; MID GAIN: 6dB
00006004: 5 ; HIGH GAIN : 12dB
00006005: 3 ; ATW : OFF
00006006: 0 ; HANDLE ZOOM : L/OFF/H
00006007: 0 ; IRIS DIAL : DOWN OPEN
00006008: 7 ; USER1 : GAIN:18*
00006009: 8 ; USER2 : FOCUS RING
0000600A: 5 ; USER3 : ATW
0000600B: 0 ; A.IRIS: ON
0000600C: 0 ; AGC : 6dB
0000600D: 0 ; ATW : ON
0000600E: 0 ; AF: ON
0000600F: 2 ; CMPNT OUT SEL : 480i
00006010: 1 ;
00006011: 4 ; ZEBRA DETECT1 : 70%
00006012: 11 ; ZEBRA DETECT2 : 105%
00006013: 0 ; SAFETY ZONE : OFF
00006014: 1 ; VIDEO OUT OSD : OFF
00006015: 2 ; ZOOM*FOCUS: mm/feet
00006016: 1 ; LCD BACKLIGHT : NORMAL
00006017: 16 ; LCD COLOR LEVEL : 16
00006018: 16 ; LCD BRIGHTNESS: 16
00006019: 16 ; LCD CONTRAST: 16
0000601A: 16 ; EVF COLOR LEVEL : 16
0000601B: 16 ; EVF BRIGHTNESS: 16
0000601C: 16 ; EVF CONTRAST: 16
0000601D: 1 ; SELF SHOOT: MIRROR
0000601E: 1 ; EVF MODE: AUTO
0000601F: 0 ; DISPLAY ASPECT: AUTO
00006020: 0 ; EVF COLOR : ON
Here is the scene file that I have been using that seems to reproduce 4:3 files:
SCENE NAME
UNCHY
00005000: 4 ; DETAIL LEVEL: -4
00005001: 4 ; V DETAIL LEVEL: -4
00005002: 6 ; DETAIL CORING : -2
00005003: 12 ; CHROMA LEVEL: 4
00005004: 7 ; CHROMA PHASE: -1
00005005: 5 ; COLOR TEMP: -3
00005006: 9 ; MASTER PED: -7
00005007: 6 ; A.IRIS LEVEL: -2
00005008: 1 ; NEWS GAMMA: OFF
00005009: 5 ; GAMMA : CINELIKE D
0000500A: 0 ; KNEE: AUTO
0000500B: 1 ; MATRIX: ENRICHED
0000500C: 1 ; SKIN TONE DTL : OFF
0000500D: 0 ; V DETAIL FREQ : THIN
0000500E: 0 ; OPERATION TYPE: VIDEO CAM
0000500F: 0 ; FRAME RATE: DEFAULT
00005010: 32026801 ; SYNCRO SCAN :
0000A00B: 0 ;
*** to here***
00006010: 1 ;
SCENE NAME
