NEVER use phantom power unless the microphone requires it. It is often a very bad idea to feed phantom power to things that don't need it. Some microphones and other equipment can be damaged by phantom power.
Very true. In the situations we usually find ourselves in in the field, phantom can be a drain on battery life if you've got it on unnecessarily.Furthermore turning on phantom power on a portable mixer, camcorder, recorder, etc. eats extra battery power and that is another good reason to leave it off unless you can't live without it.
The only time phantom is a potential for trouble is when using older ribbon mics or trying to mate unbalanced gear to your balanced, phantom-powered inputs.
