which you need for CMOS sensors, because they tend to be single chip with a filter array.
CCD doesn't have that. f3 is cmos, f35 is CCD, those are the major gains in f35 of color rendition. for a CCD camera you gain your full bit depth in your RGB per pixel, if it's 10 bit, it's 10 bit per channel. making it 30 bit per pixel. that's where you get such great color from. when it comes to CMOS, and a filter array, and debayering algorithm, there are a lot of concerns on the color rendition. which are well warranted, and what i'm trying to say is, there isn't one flavor to the recipe when it comes to CMOS, single chip, filter array. there are dozens of ways to get color information, and there is no telling how close to a f35 color rendition the f3 is capable of until dual link comes out, and you hook up a off board recorder that can give you little to no compression at it's highest quality. then, and only then can you find out how good it is.
It's actually "worse" than that. If you can't get true 4:4:4 off the chip, then you can't get true 4:2:2 either. Even true 4:2:0 might not be possible b/c you never have a full array of just green.
In practice, it seems that oversampling on the chip and demosaicing algorithms do a good job of reconstructing the image.
Uhh, what? the f35 uses one large bayer pattern sensor, exactly like the f3. It just happens to be a CCD. The fact that one is CMOS and the other CCD has nothing to do with any of this. They both operate in the exact same manor, using the exact same debayering method. The f35 just (supposedly) has more photosites in it's single sensor. I say supposedly, because nobody knows the photosite count in the f3's sensor, which is why I really wish people like Alister would quit this until we have solid information. It's nothing more than speculation, typed up like it's solid, end of the world information. Even if it has a smaller photosite count than theoretically needed to get 444 rgb output at full raster 1080, the interpolated samples from the bayer layout interpolated in the raw, 14-bit processing space will be much, much more solid data to comprise 444 than just recording 422 and interpolating to 444 in software. The fact that alister compares this to "putting 8 bits in a 10 bit stream and calling it 10 bits" is laughable, after his post on s-log and now this I'm really starting to wonder where he got his technical background. Also, speaking of bit depth, why would you bring that into the conversation? A CMOS sensor outputs raw analog voltage, just like a CCD, which is processed in a 14-bit space after being A/D'ed. When processing is done it is dithered down to the 10-bit SDI output. Just like on an f35. Their aren't "dozens of ways to get color information" and "lots of concerns on the color rendition", a single-sensor bayer pattern setup is a very standardized methodology, proven time and time again. After reading Alisters post, it's pretty clear he does not fully understand how bayer sensors comprise data. Also, nobody knows if this sensor is even bayer in the first place, or sony's Q67. So once again, threads like these are all speculation.
Uh, what? it is easily going to have a high enough photosite count to get a non-interpolated 4:2:2 image after debayer, in reality I'm sure it will have a high enough photosite count to properly debayer to 444. But like I said earlier, nobody knows what that count is so threads like this are silly. Even if the count is anywhere near 3.43mp as sony originally stated, it would have more than a full array of green to sample from.
Lexicon are you waiting to get your f3? if youre in NY and you'd like to check it out i will have one by the weekend.
That's the thing, the whole point of my post is that we do not know if it can provide enough info or not, because nobody knows its photosite count. We also do not know if it is even bayer in the first place, or rotated Q67 as sony promised to roll out some time ago. Either way, it will definitely have a full array of at least green for proper debayer, or Q67 processing. And Interesting! I was under the impression it was a Super35 bayered CCD with a smaller pixel pitch
