whats the difference?
magid1020
whats the difference anamorphic adapter and 35mm adapter? and which makes the picture better and is overall better.
An anamorphic adapter will give you a true 16:9 image using the full resolution that the DVX provides.
A 35mm adapter will give you the shallow depth of field that comes with shooting through 35mm lenses.
What looks better is a subjective thing.
magid1020 said:
what would you recommend??
It's subjective, as HorseFilms said. It depends on what you're shooting. Different projects require different hardware.
To really answer the question, type "35mm Adapter" into the search bar.
I'm not going to post a link to that search into this post, because I believe it's important that people know how to use the search function. (but mostly because i'm lazy.)
