Whats the best setting
Back to One
A loaded question I know. But if I want to preserve my quality after shooting say 720p/24pn or 1080i/24p what settings do I use when exporting to a quicktime movie using quicktime conversion? should I even be using conversion? I use FCP. (not the latest version) Ive exported quite a bit messing with the settings and with many different results. aspect ratio gets whonky etc... under size what should I put, frame, current setting? do I preserve aspect ration. sometimes I get a stretched pic. sorry if this is too much to ask in one post. just wondering if there is a common set up.
thx
there is no "common" setup. you'll have to do the math to figure out what size and aspect ratio to set your output settings. under custom size - you can do whatever you want to suit your needs.
it all depends on what (and whom) youre exporting for...?
