Shooting 24p on a 5D.
Cutting on a 29.97 timeline.
Recording audio separately. The audio should be recorded at what speed?
Thnx
Thnx
When recording audio separately to a digital recorder, there is no "speed". There is bit depth and sampling frequency which for film and video is typically 24bit/48khz or 24bit/96khz.
Higher sample rate is pretty much a waste on dialog and it doubles your file sizes.
Sorry, I have to disagree here.
It is always best to record at 24-bits. It gives you a safety headroom and is always best if you are going to do any post-production at all.
24-bits gives you the safety you need and is better than the final result.
If you only record at 16-bits you don't have the safety headroom and any manipulation will make the result worse than it could be.
So I would always originate at 24-bits wherever possible.
However - it is not necessary to go higher than 48kHz as a sampling frequency - all 96kHz does is to extend the top-end frequency response from 20kHz to 40kHz.
