Zim
take it for whatever it is worth. If the video turns out like it has really improved I might get the camera because I want a new still camera. But I will wait for more reports when it hits the street.
http://www.nikondigital.org/forum/ubbthreads.php/topics/50385/Nikon_D300s_conclusion#Post50385
1) using ALL POINTS SELECTED--auto point selection (white box) the D300s is extremely FAST. There is no more of the hesitation it used to have when you depressed the focus and waited for the AF points to light up and BEEP. The D300s focuses right up: "beep!" (check it at D300s video review ). Much much improved initial aquisition speed in BOTH the AF-S and AF-C mode. This was one of the things that bugged me much when moving over to Nikon from Canon. The delay is no resolved: AF is IMPROVED.
2) using the 70-300mm VR lens at its 300mm range in AF-C, (LOCK-ON: off, center Single AF point selection only, and release priority), the D300s is FASTER than the D300! Remember how the D300 would "slide" into focus from subject to subject (with different distances)? The D300s SNAPS into focus. As a matter of fact, I pulled out the D700 to test this side by side, and I have to say its almost the same. The focusing "torque" of the AF-S moving from area to area when tracking is the same speed and snappiness. Very very nicely done here in the AF department: Nikon did not dissapoint.
3) using VIDEO: for those who THINK the video is the same as the D90: think again! Testing the 720p video on an SD card, I panned the D300s and there is very very little "jello effect". Although I'm not a big fan of video, I took it out to film outside (filming traffic) and panned smoothly from left to right: no jello effect. I was shocked! I couldn't believe how good the video is. I liked the fact you could manually select your apreture for shallow depth of field when shooting (quite intimate).
4) 7 fps without AA!!!! This was way too cool because using the cameras drive mode without the mb-d10 made the d300 feel so light and easy to walk around!
