burning holmes films
what size in line barres do i need? for a sd mixpre to h4, they come in 10db, 20,30,and 40,,,hers the info on them from sweetwater The Whirlwind IMP Pad 40dB gives you the perfect amount of signal attenuation to effectively input a line signal into a mic pre or match levels between two pieces of gear. Attenuation is a critical part of recording and signal matching, ensuring that an overly "hot" signal won't hit the input of the device it's going into too hard. In short, attenuators are effective at avoiding unwanted distortion. An audio toolkit essential, the IMP Pad 40dB is also available in 10, 20, and 30dB attenuation versions. Take control of your signal with the Whirlwind IMP Pad 40dB.
Whirlwind IMP Pad 40dB Attenuator Features:
40dB of attenuation
Inline design
Compact design
is there an easier way to do this with a xlr cable that has them built in?
40dB of attenuation
Inline design
Compact design
