Christopher Bell said:I suspect the HVX-200 will make a superior image to the DVX as it starts with a higher res chip. Think source first.
Chris Bell
MovieSwede said:Higher res chips will not give better SD image. It can however give better widescreen image.
The res never needs to be higher than the compression permits. If a higher chipres cam gives better picture it has to do with everything else then the resolution of the chip.
Its not the source that counts, its the bottleneck.
SquidLips said:Thanks for that. But will the HVX also offer the variable frames in the standard def mode in 24P or does that not work that way?
stokestack said:Also, if you record on tape, you're limited to old DV25, which has only half the color resolution of DV50 or DV100. It would've been nice if they had run the tape at double speed and given us a nice SD recording option, but nope.
