Thank you Barry for your answer."better" in what way?
There are no 1/2" cameras under $5k, if that's what you're looking for.
The BMC is a lot less than $5k and does things the EX1R can't, but obviously there are tons of things the EX1R can do that the BMC can't, so again, the question is "better for what purpose"?
The AC130 will provide an image comparably sharp, with a lot more zoom, for a lot less than the EX1R. The AC160 will do all that and add variable frame rates and 1080/60P, which the EX1R can't do. The HPX250 will go two better by adding 10-bit and 4:2:2 recording, which the EX1R can't do; all of those are under $5K. But they're all 1/3" chipsets, not 1/2", so -- does that qualify as better? That's a question only you can answer.
It really comes down to "better for what purpose"?
The lowlight of my Brand New XF100 is not doing what I thought it could do and might just send it back to B&H.
Hijacking? Of course not. How else are you going to learn. I don't thinks its that bad but when you hit that gain from 6.0 on up, The noise is pretty bad. I am shooting a seminar right now with poor lighting. I was considering the XF100 to be my A Cam for this gig but I ended up shooting with the 5D Mark II with the 70-200mm f4.0 IS with a shutter of 50 and ISO of 1250 at f4.0. I had the ISO up to 1600 but the noise was bad mostly because the speaker had the video screen to his back which was pretty bright and no good lighting on the speaker at all.Hi
I am putting 2 XF105 in my budget for purchase. Can you elaborate on your low light complaint. Compared to what? Can you quantify it?
I haven't heard that as an issue with the XF100 /XF105.
I don't want to make a mistake. These cameras will be used for Interviews, Events, and micro-docs by a historical society. Can anyone say that the XF305 would be much better? I was thinking getting the Canon look right out of the camera with a C100, XF105 (2) 5D MKIII (mostly stills), and Vixia HF M500 (stealth and for high school volunteers to break).
Please forgive me if this is hijacking or bordering on high jacking this thread -> if so just ignore. But I had hoped to shoot lots of stuff with the XF105 and not a lot of lights.
Never had an Ex1 or Ex1r but before buying the XF100, I did consider buying one. Are you sure that the Ex1/Ex1r is that bad in lowlight? 3CCD though. My HMC150 did better than this, unless im doing something wrong. Most people are just saying to use Neat Video.I consider the EX1 to be garbage in lowlight (Can't push the gain much without massive noise). Is the XF100 that much worse or have you compared them?
I have Neat Video and will give it a shot this weekend. Thank you so muchThe XF100 is a compact pro camera and to me seems perfectly adequate for what it is. The codec actually lets you add a lot of light in post, and if you have to go to 24dB Neat Video fixes it pretty well. I've put up a one-minute clip on Vimeo with a couple of examples. An XF100 is half the price of an EX1R/PM 160/C100 so naturally you would expect to get a bit more for twice the money, but its a matter of diminishing returns.
Say what? I have found the exact opposite to be true. I've shot multiple episodes for MTV's MADE and they exclusively use the EX1 for all the shows. One of the reasons because of it's low light performance. Total documentary run and gun...NO lighting. I've shot late at night in parking lots, high school dances with strobe lights, restaurants with only pendant lighting. Never have an issue. Just put a small on camera light on the hot shoe mount and you're golden. The EX1 is an amazing camera. If you expose properly...use the right shutter speed, and shoot making the most of the light provided it def. wont let you down. Still worth the money IMO.
But...there is a slight trade off. The HD higher level gain image "fixed" by the Neat plug in is not as good as what I consider a "pure" HD image from a camera with better low light capabilities.
To me it's just a bit softer. That is the trade-off to get rid of the noise. The picture DOES look much smoother, better, to the eye. But it's not the truly perfect, crisp HD image I would prefer.
