Most of them now have electronic ballasts - I find they flicker at crazy-high shutter speeds, like over 1/1000th. Just fine at normal speeds.
EDIT: you could always take a camera to HomeLowesDepot and aim it at the display of lights to be sure. Just cycle through shutter speeds.
can you tell me any brand names or something in particular that have these ballasts and don't flicker? i would be interested in constructing my own kino flo style thing out of it
First you should decide on daylight vs. tungsten.
Then look at what sort of sockets/fixtures are available.
I had to rig a very big greenscreen and bought some 4' shop light flos and daylight bulbs. Nice amount of light and mixed perfectly with my "pro" biax flos. And cheap. These fixtures are very hard to attach to a stand and aim.
Your best bet may be to get a bunch of china balls in various sizes, and hunt around for high-wattage spiral flos. Nice soft light, and you can get 45 watt spirals (seems like about 200 watt equivalent) from Steve kaiser & other dealers. You can also take a really big china and spray paint the back black for a really ghetto softbox.
There have been many posts here about tungsten photo flood bulbs - standard household size bulbs but in the 250w range. These suckers are very hot and have a short life, and I don't think they're as efficient as the various small tungsten globes that fit various photo/theatrical lights.
The hardest thing to DIY is harder directional light. But there are usually a lot of open-faced tungsten units on eBay used, photo and theatrical. If you check regularly you can often get a deal on older fresnels in the 300-1000w range. With open faced lights, I feel getting something with barndoors (or at last something you can buy doors for) will save you a lot of hassle. You may have to buy a TVMP stand adapter for theatrical lights, which often have a pipe clamp or just a hole that a clamp bolts into. If you save a link to the continuous lighting area on eBay and check daily, you can get lucky. (click the "used" box to save a lot of page views...)
Band & DJ typer par cans may be a cheap option, but you'd want to check the color temp of available bulbs.
For broad, soft light, open-faced stuff works well - you can shoot it through diffusion, bounce it, etc - but it's hard to control spill without barn doors. I haven't seen a lot of DIY stuff in that area, I'm guessing bolting a socket into a coffee can isn't worth the hassle.
I've seen some DIY plans for biax-type flos, using aquarium-supply ballasts; but the chinese imports are getting down to $200 for a 2-tube biax - about 400-500w daylight equivalent - an the hassle of making cases, yokes, and some sort of aiming system (that weighs less than 20 pounds of plywood) makes DIYing them seem like a huge hassle when they're getting so cheap.
There's always the shop-light route, and you can lamp a shop light from 100-1000w with cheap bulbs. A lot of light, some hassles getting them on a standard stand, and the lack of barndoors may be problems, but many DIYers start there.
Overall, you may find that saving up for some import knockoff stuff is your best bet - it's not mole/altman quality, but it would be hard to DIY something to even those standards.
I built some DIY FLOs a while back-I used the Kino Flo 2' daylight lamps. I contacted the tech person at Fulham Ballasts-sent him the specs on the 2' Kino bulbs,
and he recommended their Workhorse 7 ballast. Said that this was the closest they made to the Kino Flo Ballast(NO DIMMING). From what I remember, he said that this ballast
will power two bulbs-2' or 4'. My DIY lights are 2' daylight bulbs x 4, and I use two Workhorse 7 ballasts to power them. The color temp. and the output are right on
with the Kino Flos. I haven't checked for flicker-I don't own a camera. But if you're looking to build your own FLOs, this is something you should look into! If I get a chance
to test for flicker, I'll re-post.
Is there a difference in the "look" of tungsten and colder lights like flos, if the color temperatures are machted?
Search ebay cameras & photo/continuous lighting for fluorescent - you'll see a ton of spiral stuff but also many 3, 4 and 6 tube biax fixtures - some stocked in north america, more from china/hong kong/etc;
Google Alzo digital - they have 2 and four tube units, and their non-dimmable units are on closeout, I think under $200 for twin tube biax;
There's flolight - I bought their three light twin-tube kit, pretty decent - the units have goosenecks vs. standard aiming hardware, but they're so lightweight it works pretty well; 3 lights, 3 really decent 10' stands, useable padded bags for everything, about $600 when I got 'em. Kit price has dropped, but the stands have gone from 10' to 6', not quite as useful. But good stands for flags/etc - never have enough stands.
I find the twin-tube biax stuff incredibly handy, about 500 watt equivalent or so - the plastic housing ones are so light weight, you can use them in all sorts of places, and you can stack several when you need more punch. And the light blends perfectly with daylight, seeing no spikes or casts here.
Sounds like I should try tungsten first. What kind of wattage would I generally need to light 1-2 subjects in a 20' x 20' room?
