What is wrong with this clip?
Kaisa Aho
http://youtu.be/8JxlHyDYKuc
I shot this a couple weeks ago just after I got my camera. I'm not sure why it turned out the way it did but it seems like it should have been a better quality clip.
I put it through the Raymaker at highest quality and then rendered it on my Sony Vegas 11 software. I uploaded it to Youtube and this is how it turned out.
Anyone know why it doesn't look better than this?
Hi Kaiso, can you post all of your settings for vegas please?
Both project properties & render settings & also camera settings.
Cheers Pete.
Project Properties settings:
Template: HD 1080-60i (1920x1080, 29.970 fps)
Width: 1,920 Field order: Upper field first
Height: 1,080 Pixel aspect Ratio: 1.000 (Square)
Frame rate: 29.970 (NTSC)
Steroscopic 3D Mode: Off
Full-resolution rendering quality: Good
Deinterlace Method: Blend fields
[box checked] Adjust source media to better match project or render settings
I can’t find the render settings and I’m sure I have changed my camera settings since then so I don’t know what it was set to.
Thank you!
Do you know wether you were recording interlaced or progressive as that makes a big difference.
i have just been through a similar thing with regards to Vegas settings & end results so I will sit down after work & go through some stuff.
The metadata should be stored somewhere in the file to tell you what the settings are.
ill have a look tonight where you would find it as I have never had to look for the metadata.
ND filter would have definately been an advantage to bring back the sky.
As for your vegas settings, i would set the render quality to best, pixel format to 32 bit video levels & use the Main Concept, internet HD 1080 as the output format.
Just this week though i have been looking into the sony settings from another problem i had & it seems that the vegas output is pretty ordinary.
There is a product called handbrake that you can render MP4 files from so give that a try.
I am going to download it over the weekend & have a go at using it.
Cheers Pete.
