What is the straight dope on squeeze mode?
filmtovideo
I saw this elsewhere:
"4:3 SD (i.e. the DVX100) is 720x525 (NTSC) or 720x625 (PAL) lines. To achieve 16:9, it crops or squeezes the image into 720x480 lines
Therefore when shooting 16:9 on the DVX100a, you might lose anywhere between 45 - 145 horizontal resolution lines, depending whether you're shooting NTSC or PAl.
you will still have to make a subjective call about whether you are happy with the resolution loss. "
Do you know if this is the same as the 'squeeze" mode on the Panasonic
Dv-30?
Also, the DV-30 has a letterbox mode. I've heard conflicting opinions on
whether letterbox is superior or inferior to adding letterbox in post based
on people saying that letterbox wastes pixels or uses pixels more effectively.
I don't know what to think.
Also, I read:
"Another option is to shoot 4:3 (full resolution) and the up-rez the footage to 16:9. There are a couple of fairly good programs that do this. (Photozoom, Instant HD...)"
If letterbox works, why would you do this? I use the DV-30 and the HVX-200
but I haven't used the DVX so I don't know if it has "letterbox" mode. I like
the DV-30 but wonder about the best way to get a widescreen look without
a native 16x9 chip.
Thanks.
