We have the Steadicam Flyer using the DVX100A cameras. Since this camera is only 4lbs, we had to add some weight, around 5 or 6 lbs to add some load to the arm. I hear the HVX weight is a little bit more but you would most likely need to do the same. As far as your weight, I have seen some women flying a master series Steadicam with a full bolwn 35mm camera. I think you would be fine with the Flyer. Just practice and maybe attend a Steadicam workshop. Check out Tiffens website on the Flyer specs.rogar-BigGrin(DBG)
We have the NP1 Batts due to them being inexpensive along with a quick charger. I think BigStein is getting ready to convert over to some v mounts.
With the NP1s, you have to lower your battery arm adjustment to take them out for charging therfore rebalancing is going to have to be redone.
I would really consider the v mounts. The Flyer is awesome!:love4:
