Pascal Parvex
I did some research about the squeeze mode some cameras have, including the DVX100A. Somebody wrote in a newsgroup posting I found that the Sony 900 squeeze mode is just removing the upper and lower black bar and then interpolating, so you don't have to do it in post production. Is the DVX-100A doing the same? And why is an anamorphic adapter better?
Another question: I shoot in squeeze mode with my DVX100A and capture the footage with in-sync Blade. If I play the footage with Windows Media Player 9, it's correctly properly in 16:9 'out of the box'. But if I eport a segment of the original captured footage with Blade, to whether DV Cinema, DV NTSC or DV PAL, it's displayed as 4:3. Is there a way to set a flag before exporting that tells the Windows Media Player 9 (or other players) to stretch/display the video as 16:9 as it does with untouched footage? Is Blade just not able to handle the new squeeze mode on the A model? Because in Blade, for 16:9 display, you have to stretch the video windosw manually to get somthing like 16:9.
A final question: Is exporting a segment (with Blade) lossless or will I loose image quality, maybe even the progressive frame information?
