mmm said:I am not quite sure what you mean. I depends on the situation and the tape. Digibeta will have virtually no visual loss. VHS has a lot.
I guess you mean DV though. Gltiches and dropout are obviously very bad, but can be greatly reduced with clean heads, good tapestock and using DVCAM or DVCPRO if possible. You will loose some quality in recording to DV because the codec uses 5:1 compression. However, the actual visual difference of the camera output and tape output is quite small. IMO the DV codec is not the limiting factor in making your footage look good - it is the camera and the operator.
DV introduces "blocky" compression artifacts to the shot like a jpeg still image. These can be had to spot on motion video, but are evident on freeze frames. Fine detail suffers worst, stuff like trees, hair etc can look a quite blocky especially on a big screen.
Barry_Green said:Dropouts can come in varying strength. The weakest ones, the "sparklies", will corrupt a few pixels here and a few pixels there. The nasty ones, the "venetian blind" dropouts, will cause your whole picture to break up into 9 horizontal bands, where 4 or 5 will be frozen solid and the rest of the image keeps moving.
DV also employs error correction to mask dropouts, so you may be getting more dropouts than you know. Of course, a properly masked dropout is probably irrelevant, so that may not be of much concern.
