Hi guys,
I played with ptool changing settings, uploading, changing setting again to find the best stable configuration and to my surprise trying to reupload on more time the camera doesn't see the update on the card, though I check "prevent version compare". TWhen I press "play" it shows "NO VALID PICTURE TO PLAY".
Camera shows 1.32 version. Probably last time I repatched I forgot to check "prevent version compare".
Any way I can get over this? The worst part is that I have settings that freeze the camera after a couple seconds and it cannot be used this way. I did a search here on dvxuser without much success.
thanks in advance for any help
Rene
OK, I fixed it. For future refference in ptool I incresed the version 11 steps (tried everything up to 10 and didn't work) though I checked "prevent version compare" and increasing the version or even check it shouldn't matter. Reset the camera to factory settings and removed the bat for a couple of minutes. After I pressed play the camera saw the upgrade.
Rene
