what’s the most reliable way to judge exposure on the FS700???
Question for all FS700 users. What is your preferred tool for accurately judging exposure when shooting with the Sony FS700?
Do you feel the zebras and histogram are accurate enough, or do you prefer an external method for greater accuracy?
Just asking, because I'm still trying to get my head around the tiny little histogram. Is there no way to increase it's size on the screen?
I'm liking the histogram/zebra more than ever - can't believe how I used to blow out exposures with the AF100.
Zebras @100% and never exceed them, Cine2 and let the histogram float around 40-60ire.
Agree it is small but at least it shows on an external hdmi/sdi monitor.
can’t get the histogram to display in the slow motion setting - is there a way to do this?
Thanks,
Bill
I think only the zebras work in S&Q mode, unfortunately. (I'd be happy to be proved wrong though)
You can use the histogram in normal mode to check your overall exposure/ratio, and then switch to S&Q mode and use the zebras to dial it back to the correct exposure.
Or set up your exposure and then use the ND's or aperture to increase exposure. It is easy if you always use 180 degree shutter.
ie: 1/60 - 1/480 is 3 stops (if you shoot 30p).
An old fashioned light meter works great as well, to figure exposure based on shutter speed-ISO-aperture.
I still have 2 of the trusty Gossens.
I was wondering about using a light meter. I have an old Minolta and was fiddling around with the settings. I was thinking that setting the Minolta to CINE 24 would work just fine, but do you have any other suggestions for setup?
