Zacatac
So I got a SD to CF adapter to be able to use my FW800 CF reader to dump footage faster in the field. But it seems that I'm getting worse transfer rates then using my USB 2.0 SD card reader. Any possible reason why this is occuring? Its the same exact file (renamed to -2.mov) dumping at the same time to the same place, and the rates are crazy slow.
FW800 SD-CF Adapter- around 15Mbps
USB 2.0 SD - around 20Mbps
Thats insane, and doesn't make sense why its so slow, I SHOULD.. be getting at least 60Mbps out of the FW800, since I usually do. So why is this adapter cause such a slow transfer rate?
