brandondull
I am experiencing vertical lines while shooting on my HVX200a. They are off center to the right on the frame. Does anyone know why these are appearing?
I have also put more frame rates on a SD card and loaded them into the camera. Could that be a possibility of these vertical lines showing up? I have started to experience the lines after the frame rates were loaded into the camera.
Can anyone help to reset the scene file settings to factory settings or fix the problem as is?
Thank you much,
Brandon Dull
Thank you much,
Brandon Dull
