A lot of factors here.
You told us 1080p, but is it:
AVCHD, MOV, MP4(LPCM) or MP4?
24p, 30p or 60p?
20, 24, 28, 50, 100 IPB, 200 All-I?
iDynamic on?
iResolution on?
Looks like Cine-D. Tweaks to any of the variables? (contrast, saturation, sharpness, noise reduction, etc?)
ISO?
Variable frame rate on and if so what frame rate?
Mode: 200Mbps ALL-INTRA LPCM
MOV
iDynamic STANDARD
iResolution STANDARD
Cine-D - Everything -5 except for Hue, which is +1
ISO 400
No variable frame rate.
ok I may be having a moment but when I play back gh4 footage in fcpx its soft if when it stops the frame is sharp....
Looks like it's figured out, but in high detail scenes, I've heard "All-I" recording is actually less effective. IPB mode actually analyzes preceding frames and predicts where the bit-rate should be utlized, while All-I just weights everything equally. I never use All-I... but your mileage may vary.
OP hasn't actually replied to any of this, someone else just had an epiphany during the thread.
I encounter the same issue as OP but only for the first frame of most clips, never has it continued into any of the useful portion of a clip.
I'm curious as to the outcome.
I think the problem was that I took the camera out without changing any settings at all. I reset the camera and made sure idynamic and iresolution were off and it looked a lot better.
