puredrifting
Major Contributor
Hi all:
Did a shoot yesterday, used my 170 and then asked producer to rent a second 170 for a different camera angle. We shot about two hours worth of footage and I dumped all of the shot cards to two hard drives for backup. Used a Panasonic single card USB reader and yes, of course I locked the record tab before inserting the card into the reader.
I am going over the footage today and one of the cards from the rental camera didn't seem to work right. I have been shooting P2 since it first came out and I have never ran into this issue.
1. The card shows 6.29GB of material on it. When you click on the contents folder, only two sub-folders show up, Audio and Video. No Clip, no Icon, Proxy or Voice folders show up? Within the Video folder are two .MXF clips, one is 4.25GB, the second is 1.87 GB. In the Audio folder are eight .MXF files, as you would expect, four for each video clips. So there is material on the card, it did record, but somehow the card structure is incomplete. P2CMS and FCP 7.03 Log and Transfer do not show anything, obviously because the file structure is incomplete.
2. Also, the LASTCLIP.TXT is there, but it is greyed out and is not locked like all of the other cards LASTCLIP.TXT icons are on the other card. Also, all of the other LASTCLIP.TXT show that they are a 4KB file, this LASTCLIP.TXT shows 0KB.
Has anyone seen or experienced anything like this? Is it fixable? I may load the material from the drive back to a card and try to "repair clips" using the camera? Any other options or advice? I am flummoxed because P2 always just works, I have never had to do forensic reconstruction to get a card to work. If it matters, I am on a Mac, OS 10.6.6 and all of the other cards from the shoot from both cameras worked fine, just this one didn't.
Advice?
Thanks,
Dan
Advice?
Thanks,
Dan
