earmarkcreative
On a recent shoot, I got a really odd color shift when using ND glass filters in a matte box on the HPX500. I tried everything, black balance, white balance, changed the scene files, changed lens (I tried with both a canon and fujinon) we tried different brand filters (Tiffen + Schnider), SAME PROBLEM each time. We then tried the filters on an HVX200 and got the same problem.
We tried it on an HDX900 and voila, no problem. After some asking around, I found out that apparently the IR filters in the "lower-end" P2 cameras isn't that great (thus the prices I guess? ) The only solution is to use a pancro filter.
See the image below for an example. A few things to note when viewing the image:
1) The guy's sweater is BLACK! His cap is red so fairly accurate to what you see here.
2) Its not a white balance issue since there is no color cast and the grass is still green and there is a bit of blue in the sky to the top right.
3) I think an ND6 was loaded at this time.
I am just wondering if anyone else has had this problem with their HPX500. Panasonic Canada is currently baffled by this discovery too. They are working very hard to recreate the shooting scenario to get to the bottom of this.
