Weird AF100 TC Slave thing...
jmarkham
So .. was on set today with a Deneke SB-3 feeding the TC into an HPX300 .. the TC out
going to the AF100 into the video signal ( with a BNC to RCA adapter ).
Both cams were in 1080p30 (NDF) ..
The AF100 was set to TC free-run
I went to the TC/UB menu and chose the TC sync menu .. chose SLAVE .. and
then pressed the TC Set button .. The display said TC Link .. which I would expect.
However .. the time on the AF100 did not sync .. it was about a second behind.
The HPX300 sunk perfectly to the SB-3 TC Generator.
I power cycled the AF100, toggled it to Record Run .. and then back to Free run and
re-sunk.
I also tried bypassing the HPX300 and going directly to the SB-3's TC-out .. no difference.
Very strange ..
Any ideas?
thanks
jeff
ps: Also, the Start/Stop1 button started acting up .. it would start .. but wouldn't stop .. very odd.
I don't think so. If the BNC -> RCA adapter wasn't working, I don't believe I'd be getting the TC Link message
after pushing the TC SET button. I'll keep playing with it...
jeff
